주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod nano 6세대를 위한 수리 정보. 2010년 9월 출시. 모델 번호: A1366.
New Battery won't Power Device
I bought a new screen and battery to repair an iPod Nano 6th Gen. I soldered in the battery and it said no charge, so I put it on the charger and the device turned on and I left it, but when I came back and removed from the charger it dies and says it needs to charge even though it shows a full battery and it is charging when I first plug it in. I put the old battery in and no issues other than it only holds about 20 minutes worth of charge. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Ended up clipping the cables a little shorter on the new battery after noticing a crimp in the cable and resoldered it in. Working now.
의
댓글 달기
답변 2개
가장 유용한 답변
Well it can be simply that its a bad battery you bought.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My guess, a bad battery. You said it was not charged when you got it. This is an older device so who knows how long the battery you got has been sitting around for. Lithium-ion batteries don’t hold up well when they are discharged and it can actually cause damage to the battery. I would try another battery from a reputable source and see if that makes a difference.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Arianne Morton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 416
