주요 콘텐츠로 건너뛰기
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 질문 전체 보기
I over loaded my washer and it overflowed and won’t get any power..
I stuffed a huge blanket in the washer and I guess it made the water overflow. There’s water on the floor but not that much. But the power is out on the unit completely. The washer and the dryer. I tried resetting the electricity breaker switches for the laundry room but still nothing. I don’t know what else to do…
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi
What is the make and model number of the washer / dryer combo unit?
Did it trip the breakers or did you just reset them both (turn off / turn on)?
It may be that the water caused an electrical problem with the washer / dryer’s control board.
With the power totally disconnected from the washer, open up the washers control panel and check for any obvious damage to the control board e.g. burn marks, blown components etc.
If you spot any damage (or even if you don’t) and are not quite sure, take some close up pictures of the board and post back here.
Here’s how to do this.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Are these connected to a GFCI Outlet? These are the ones that have the two little buttons on the wall outlet. These are often installed in areas around water such as kitchens and bathrooms. These are designed to work like a breaker but at the outlet level. If you see two little buttons try and press the one that says reset.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jennifer de la rosa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 57
