주요 콘텐츠로 건너뛰기
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
20 질문 전체 보기
Roller brush doesn’t turn - Shark Lift-Away brand
I have a Shark Lift-Away, the brush has stopped turning. I have cleaned it, etc.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
My roller also stopped working. It would be nice if you could remove brush to see if there is hair wrapped around where the brush connects.
@yazminkuba18603 You can remove the brush, but it's not just a matter of snapping open a couple of latches on these machines; there are like 10 screws that have to be taken out but it is doable.
Shark Navigator Roller Brush Replacement
댓글 달기
답변 4개
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
That instruction is basically clean it, it doesn't have an answer.
Mine just doesn't work no .atter what I do
댓글 달기
have check all obvious problems but brush roll wont turn
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I'm having the same issue. Is there a reset button for the beater bar(brush roller)?
Mine won't even turn manually.
댓글 달기
Brand new right out of the box will not pull or push spin brush does not work.... WTF is the problem with this vacuum
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Take it back, why worry?
댓글 달기
It is either:
A stuck brush because of debris
A bad or broken belt
A bad switch or connector
A bad brush motor.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Barbara Glosson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 87
전체 시간: 5,534
