주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
111 질문 전체 보기
Fan shaped dirt at the top of my screen 2.16 intel
I have an intel 2.16 24" iMac and at the top of the screen there is an upside-down sun burst of dirt between the LCD and the protective plastic that covers it. Is it possible to separate the actual LCD from the plastic so I can clean the stripes? This is the older white plastic "Pizza Box" version.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
On this iMac model there is no extra part between the LCD and protective film. This seems like something on the LCD. I would think you have to change the LCD. This is not very difficult and you can find a good used on on ebay.
I found some for you here:
http://shop.ebay.com/i.html?_from=R40&_t...
The Apple part no. is 661-4184 (see the parts here: http://www.welovemacs.com/apim242inco2.h... )
Here is the guide. Take your time and use your fingers a lot, don't be tempted to use force.
iMac Intel 24" EMC 2111 LCD Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Thanks, i kinda thought that was going to be the answer, not bad enough yet to need replacing. thanks for the help and the links, I will check them out
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tony C 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 537
