주요 콘텐츠로 건너뛰기
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 질문 전체 보기
CMOS battery on Asus x540y
Where is the cmos battery on Asus x540y taking the laptop apart and can not find anywhere.Please show step by step on how to find and replace.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Shane Wigum it may not have one. If you removed the motherboard take a look underneath the board. IF you cannot locate it there either it is easily possible that Asus is using a capacitor instead of a CMOS battery. It would get power from the main battery. Anyhow, let us know why you need to replace it and post some good pictures of your motherboard as well as the chassis with your question so that we can give you a more precise answer.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
hi
there is no cmos battery in your laptop model just the main battery of laptop
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
이미지 내용 보기:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shane Wigum 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 38
전체 시간: 2,594
