주요 콘텐츠로 건너뛰기
The Samsung UN55KS9000F 55-inch 4K SUHD TV is a flat panel 2160P TV. Released from Samsung in 2016. Model number: UN55KS9000FXZA.
27 질문 전체 보기
Samsung mu9000 Large moving light dot.
I am looking at buying this TV.There is a fairly large shifting
white circle on upper edge of screen on menu and some streaming sources.Wondering if this can be fixed.I think it is edge lit so I am puzzled what this could be.Thanks for any advice.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@zook5972 this could be a delaminated LED on your backlight strip. Those however usually show up behind the video and not in front off it, hard to tell on your images. You will have to disassemble your LCD panel to determine the exact cause for it. Worst case would be a bad panel. So if you are going to purchase it, buyer beware and make sure you do not overpay.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks.This is edge LED so I can't figure how
that would cause this dot especially with it changing position.Not my TV was thinking of buying it then this issue arose.
If it delaminates it loses the diffusion and can appear as a circle. When you refer to it as moving do you mean that it expands or does it show up in different locations?
댓글 달기
귀하의 답변을 추가하세요
David N Phillips 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 108
