주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1999년형 모델을 위해 1993년부터 1995년까지 캘리포니아 샌디에이고에 위치한 Nissan Design America에서 Diane Allen의 주도하에 Quest가 재설계되었습니다.
Headlight not working like it should
My driver side headlight doesnt turn on most of the time and my highbeam light stays lit on the dash regardless of if the highbeams are on or not when the headlight does come on the highbeam light on the dash turns off not sure what to do any advice is greatly appreciated
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
Either there is a problem in the headlamp control unit or a wiring problem for the driver’s headlamp operating circuit.
Here’s a link to the electrical wiring section for a 2000 Nissan Quest.
On p.EL-32 there is a description of the low beam headlamp operating circuit.
On p.EL34-35 there are circuit diagrams for the headlamp circuits including the instrument panel high beam indicator light.
On the following pages are diagnostic tests for all the lamp circuits e.g. p.EL-42 headlamp control unit inspection table showing what voltage should be present on which terminal in the control unit under what circumstances
Hopefully the manual will help you to find the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
doomcrush 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 27
전체 시간: 695
