주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
iPhone wont turn on after display swap
I replaced the cracked screen on an iPhone and it worked fine afterwards. However the day after, it would´nt turn on.
I already plugged in another battery but still same result. It won´t show up in iTunes.
I used 70% Isopropyl 30% destilled water to clean the phone, has it maybe caused some corrosion?
Thanks for your help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I would take a step back and start by re-installing the original screen to see if the problem is consistent with the screen or the phone (logic board). I would also closely inspect the flex and connectors to insure there was no damage from the repair. Quick question - did you disconnect the battery prior to removing the display, and connect it only after the display was re-connected?
The other thing to try is to remove the screen altogether and connect the phone to an iTunes enabled computer to see if it is recognized. While you’re at it, you could also remove the RCAM and button flexes and keep the phone in a minimalist state.
My concern here is your cleaning process. In theory, distilled water in contains no minerals and is non conductive, so you’re approach to cleaning the device is sound. However, in practice, its possible that the “pure” water you used was not as pure as you thought or were led to believe.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I didn´t disconnect the battery when I installed the screen, but the iPhone won´t show up in iTunes so I think the screen shouldn´t be the problem. Nevertheless I will try using the old screen tomorrow.
댓글 달기
귀하의 답변을 추가하세요
Philipp Udwari 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 35
