주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Brother printers.
352 질문 전체 보기
Brother HL2270DW Reports Paper Jam or No Paper
Printer shows Orange error LED. Supposed to mean out of paper or paper jam. Trouble is, there is lots of paper, and there is no jam. Printer works fine in manual feed. Will not feed from paper tray. Rollers have been cleaned. Any ideas how to get the LED to turn off and enable printing from paper tray?
Drum and toner are brand-new .
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
I had this printer for many years and never had a problem with it, printing large files. I had to move things around, and when restarting recently it just did not want to work at all, never got a sheet through. Bought another newer unit on EBAY, and it does the same. I believe the newer drivers or program does not allow enough time for the paper to load. I would like an original driver. Maybe I have the the floppy I started with. In all my years I just loaded the tray and forgot about IT! The new driver is not even Brother.......OH BROTHER!! TOM
댓글 달기
답변 3개
가장 유용한 답변
The Real Answer can be found here
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
bait & switch--they just want to sell toner. don't waste your time
댓글 달기
Please check the back panel of your printer, may be there is any some piece of paper available inside the printer, that’s why you are getting this error.
How to fix brother printer paper jam issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
As @theprinterman alludes to above, the real problem is something called the “drive gear engagement arm” - and if you’re feeling even *slightly* handy, you can fix this - with nothing more than a spudger (or a butter knife).
See here: HL-2280DW paper feed not working
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
FIXED! Thank you so much.
댓글 달기
귀하의 답변을 추가하세요
David Bogart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 29
전체 시간: 2,693
