Why does it say special lens error: 0x221
why does it say special lens error: 0x221 when i turn the camera on
좋은 질문 입니까?
좋은 질문 입니까?
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
해당 답변은 도움이 되었습니까?
try what to free the lens from the barrel?
해당 답변은 도움이 되었습니까?
click on the light blue "this" in the original answer. It will take you to a few things you can try.
what frees the lens from the barrel?
eddie jemison, did you visit the link? Have you tried any of the solutions that are suggested there? Those can free it, at least 2/3 of the time. Anything else will require a disassembly as well as a possible replacement of the lens
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 511
