주요 콘텐츠로 건너뛰기
The Sony Handycam FDR-AX33 is a palm sized camcorder that combines 4K video with video stabilization. It was released in March 2015, and was the first camcorder to introduce the new Balanced Optical SteadyShot (BOSS).
How to fix E:61:10 flashing error in my Sony FDR-AX33
E:61:10 flashing error in my Sony FDR-AX33 I dropped it once.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
If I need to replace the steady shot assembly, where can I get this fix near me in Mansfield, Ohio. and can i fix it, or replace it myself.
댓글 달기
답변 2개
가장 유용한 답변
Georgio7564044 Error code E: 61: 10 possible cause for that is an Issue of the zoom driving part. This usually requires a new lens since parts for the internal workings are most often not available. You can always try what is shown here.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I found the solution from trial and error while I was attempting to fix my camera. There’s a tiny circuit board with a chip attached to a ribbon and red and black cables on the right side (from your perspective facing the viewfinder/eyepiece) of the camera when the shell is disassembled. I’m assuming that’s an accelerometer or other sub-processor for BOSS. Remove it and reseat it to reset the chip.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
The one just above the headphone output and mic input?
댓글 달기
답변을 추가하세요
georgio7564044 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 30
지난 30일: 165
전체 시간: 8,147
