주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP G71은 HP에서 생산한 노트북 시리즈입니다. G71 노트북은 모델 번호 G71-XXX-XX로 식별할 수 있으며, 마지막 문자는 옵션 및 판매처에 따라 달라집니다.
Why don't my USB ports work?
I've noticed recently that both of the USB ports on the right side of my G71 are not working correctly. Whenever I plug a device into the top one, I get a "USB device not recognized" message, and plugging something into the other gets nothing at all. The third USB port (on the left side) works perfectly fine.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Try reloading the USB drivers. Cheapest easiest fixes first then dive in to innards.
my cd roma worked until I update my window
댓글 달기
답변 2개
선택된 해법
I finally opened the computer. The ribbon cable from the USB board to the motherboard was unplugged at the motherboard. I now have all 3 USB ports functioning again!
이 답변이 도움이 되었나요?
점수 4
댓글 달기
I would remove the keyboard and check to see the connector for the USB ports on that side is firmly connected. If it is check the ports carefully for damage or debris. I am including a link the the service manual. Good luck.
h10032.www1.hp.com/ctg/Manual/c01713747.pdf
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thanks for the link, I'll be sure to try that.
Definitely appreciate the link. Thanks for your help in this.
댓글 달기
답변을 추가하세요
David Hodson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 14
전체 시간: 3,681
