주요 콘텐츠로 건너뛰기
더 커진 Samsung의 주력 핸드폰. 2018년 3월 출시.
130 질문 전체 보기
Can I use 95% ethil alcohol instead of Isopropyl?
I cant find Isopropyl alcohol in my country. I want to make glass only repair on my galaxy s9plus. After removing outer glass can i clean adhesive on LCD using ethil 95% alcohol(ehtanol)??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sure you can. I use methanol. Both are more volatile than alcohols diluted with water. I use a syringe to shoot methanol under the glued in batteries on MacBook Pros. The iFixit kit uses acetone.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Hi,
I would be wary about using Ethyl alcohol to clean electronics but that is just me.
Here’s a link that may help you to decide. Although they are talking about laboratory grade Ethyl alcohol and not standard grade.
Is “rubbing alcohol” (usually available from pharmacies) available where you are? If so you may be able to find some “rubbing alcohol” products that are ~70% IPA and water which may be less risky to use on electronics than Ethyl alcohol. Just a thought.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
giorgi dzidziguri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 29
전체 시간: 1,617
