주요 콘텐츠로 건너뛰기
Power Mac G4에는 Mirrored Drive Doors가 있습니다.
80 질문 전체 보기
G4 MDD Strange Graphic Bug
Hello! So I have an PowerMac G4 MDD which had a broken PSU, so I bought an ATX PSU and modded it so it works with a Power Mac G4 MDD. It booted up, pressed the ALT key on the Keyboard so I can choose an hard Drive to boot from and saw a very strange Graphic Bug.
The machine is responding and I can move the mouse cursor and such. What is the cause of this Bug ? Is the GPU broken? Or my modded PSU ?
Thanks in advance =)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@eneas64 it will become important to know if it worked before you replaced the PSU. If it did you know it’s your mod PSU. If you do not know it is possible that this is the GPU. Make sure that your mod is absolutely correct. If does sound and look like a GPU issue but any time you use a modded component it can do some extremely weird things
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Eneas David Sohrabi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 43
