주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iRobot Roomba Red 4100은 iRobot에서 생산한 로봇 진공 청소기로, 혼자서 방 안을 청소할 수 있습니다.
Cleaned machine, still not working?
When I turn my roomba 4100 series on, I get the 4 beeps, which indicates that a wheel motor cannot run. I have cleaned all parts and removed any debris. It still beeps 4 times. There seems to be nothing stuck around the wheels or brushes. Help!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
nicole, turn it over and look for something caught in the wheels. Test wheels by pushing them in and out and making sure they rotate freely. Of course, if you have already tried that and it did not give you any results, then you need to try to run the self diagnostics. Here is link link to a really good site that will show you how to run diagnostics on your Roomba. It should help you to narrow your error down. Also check this link for more info (you are not alone with that problem:-) download the service manual from here. Make sure you save it, apparently iRobot does not like us to look at their manuals :-) Good Luck
이 답변이 도움이 되었나요?
점수 2
댓글 달기
how to reove battery how to charge
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
davidgetchen, click on the link on the right side of this screen "Ask a question" and give as much DETAIL as possible for your ROOMBA. Model and serial numbers are very important as well as letting us know what you have tried to fix it. Also let us know what the symptoms are :-) and if you have tried the user manual yet.
의 공유
댓글 달기
답변을 추가하세요
nicole 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 2,756
