주요 콘텐츠로 건너뛰기
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
85 질문 전체 보기
Left ear stopped working. Dead driver
Hello
I have the hyperx cloud alpha, out of nowhere the left ear stopped working, i saw some guides over here said that it could be a faulty wire so i tried to investigate and found that the left speaker (driver) is dead (i tested the drivers with some voltage the right driver made some noise while the left one is completely dead)
My question is this thing fixable ? Anywhere to buy the driver or if i managed to get a broken cloud 2 can i fit its driver in the alpha?
Thanks for any help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@bahaa_ay you would have to actually take some physical measurement for the driver to see what might fit. I would try and scour places like ebay, craigslist and pawn shops to see if you can find a donor headset from where you could transplant the driver.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for taking time to answer my question I found a cheap cloud 2 for about 20$ but the driver on the cloud 2 is 53mm while the alpha is 50mm
Do you think it might fit?
Sorry but no. It will not fit the housing.
ok thank you
댓글 달기
귀하의 답변을 추가하세요
Bahaa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 1,093
