주요 콘텐츠로 건너뛰기
Acer entered the world of laptop computers in 1997 when it purchased Texas Instruments' mobile PC division.
1684 질문 전체 보기
5.9 GB Ram only usable out of 8 GB Ram. How to fix?
I’m having an Acer Nitro 5 Ryzen 5 Quad Core - (8 GB/1 TB HDD/Windows 10 Home/4 GB Graphics/AMD Radeon RX 560X) AN515-43 Gaming Laptop  (15.6 inch, Obsidian Black, 2.3 kg) laptop. It shows 8 GB Ram. But I can use only 5.8 GB Ram usable. It is having AMD Radeon RX 560X 4GB graphics. But it’s primary graphics is AMD vega 8 graphics having 2 GB graphics. 2.1 GB of RAM is hardware reserved. How can I get 8 GB of RAM fully usable?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
you have to turn off the igpu
댓글 달기
답변 3개
선택된 답변
Go to the BIOS and check it , it is sharing the memory with the VGA even though it is showing dedicated VGA
but if you reduce the VGA Memory it will have some performance issue like when playing games, or 3D applications
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
In my BIOS settings, there is no option to check for memory sharing or not refering anything about VGA graphics.
same goes to me, i thought the problem is just only mine. went to the centre and they said this could not be fix...adding up the ram will only the way of it.. they also said dont be worry about reserved because it gives you same performance when you use the those graphic card...like playing games, editting.etc.
already did upgrade the ram from 8gigs to 24 and now its reserved to 6.21 out of the whole fkin 24gigs seriously wtf
댓글 달기
Just upgrade the RAM:
https://www.windowscentral.com/how-upgra...
Remember to match the pair of RAM for best results, so that means
same size, same brand and same model number.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
you can actually change how much of ram is hardware reserved through the bios ….however the catch is that you have to get to the “advanced” bios(not the one we get while pressing f2).the so called advanced bios can be reached by pressing a combination of keys on startup which no one knows(trust me i looked a lot)…..,another way to get to the “advanced” bios is by flahing bios from a usb which you can find the tutorial for it in youtube…i wouldnt recomend cause i personally didnt do it,nothing wrong with it(it might void your warranty tho).
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
hey could you post a video instructing how to flash bios.
댓글 달기
귀하의 답변을 추가하세요
[deleted] 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 78
전체 시간: 17,724
