주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
iPhone 4s battery connector fix with 2 broken connector pads
Hi guys! Thank you so much for advising me on my iPhone battery connector issue.
While taking out the battery, I tore off the battery connector and 2 connector pads. I haven’t soldered before and was wondering what exactly I should do to fix this. I have a spare connector. I came to understand that the two connector pads that are gone are resistors and therefore could to be shorted? (Do I just need to connect those using a copper wire?) I might need to bypass the first connector pad too…
I’ve included a photo:
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Is it for data recovery purposes only or are you trying to make a workable phone out of this? I think the first question you want to answer here is just how much time and effort you want to put into an iPhone 4S.
Below you will find the schematic and boardview of the battery connector.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you Minho! The point is to make a workable phone.
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 101
