주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
HDMI PIN 18 issue
Hello everyone,
I bought PS4 with faulty HDMI port to fix it, learn something and get some practise. I am now waiting for my new HDMI port, but I have noticed something on the bord. As I checked conductivity between PADs and points from the diagram, I found, that PIN 18 is not connected to the capacitor on the right side(18).
I have also noticed that the back side of the diode and capacitor(Yellow dots) are connected and both shorted to ground.( Front side of the diode and capacitor Is connected too, but not shorted to ground.) Is that right ? I dont have another board to compare with. And if yes, where does PIN 18 go? Could that be an Encoder IC fault?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 3개
@marcinn ..please list which board you have for further diagnostics help
Where can I get that? Theres SAB-001 on motherboard, Is that it?
댓글 달기
답변 8개
가장 유용한 답변
martin … for sab-001 follow this pinout.
https://www.youtube.com/watch?v=KTQ5JkaL...
skip to the end for the testing points. if it doesnt match, theres a fault. post back for further assistance.
이 답변이 도움이 되었나요?
점수 1
댓글 10개:
Yes, the PIN doesnt match the video
youll want to remove the component that doesnt match and test out of circuit. if it tests good, place it back and continue. something is shorted. it could very well be the hdmi contoller. i would start there and recheck the pinouts.
Okay, I am gonna try that, thank you
@jostewcrew so I have desoldered the diode and capacitor and noticed, that I have 3 pins on the HDMI controller (firts 3 from the left side behind the HDMI filters) shorted together. Dont you know where they should connect ? And when I removed the components, the pin Now connect to the right place
Sorry, not only First 3, also some that Are connected to HDMI filters are shorted with first 3 pins
댓글 5개 더보기
댓글 달기
Hi, I have the same problem, maybe someone could give us feedback about value of this cap and diode from working MB. For me its 1,5 Ohms from the left side of thie components.
Thank you!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
14 pin point root i want
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i need help!!!!!!!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i need help!!!!!!!! andrew!!!!!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
how to get sab-001 ps4 hdmi disgram motherboard!!!!!!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Capacitor and the diode are both grounded (caps negative if polarized diodes non-striped side)
Capacitor is noise filter
Diode is a protection for polarity
Both are for local part of circuit
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hey friend, do you happen to know which ceramic capacitor is the one next to the zener diode?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Martin Jančík 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 28
지난 30일: 158
전체 시간: 13,051
