주요 콘텐츠로 건너뛰기
Model A1213 / 8, 16, or 32 GB capacity
216 질문 전체 보기
Shows up as "No Wireless" - just grayed out
Hi. I just replaced the battery on an iPod Touch 1st generation that was working fine before, but now, after it's put all back together it works great except the Wi Fi option is just grayed out, saying "No Wi Fi". I suppose I must have bumped something when reassembling, but how do I fix it? Is it the small antenna wire at the top that is causing this or something else? Do you think I just need to re-align the antenna or is there something else that might have gotten mixed up?
Thanks for the help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
I would open up your iPod again and check the connections. The WiFi antenna is connected to the logic board by contacts points only. Make sure that those points still make contacts with the board. Check the guide on here. Of course, check and double check all other connections as well. Hope this helps, good luck to you.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Great thanks, I didn't realize it was only connected by the contact points, I thought I might have broken it off but wasn't sure. It was a bit corroded, so I think I'll try replacing it with another one. Thanks!
Good luck, hope it works for you.
댓글 달기
귀하의 답변을 추가하세요
iTronics Repair 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 23
전체 시간: 2,208
