주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
Replacement screen not flush with bezel; home button doesn’t work
Followed instructions for replacement—all appears to have gone well, except home button doesn’t click, Touch ID doesn’t work, and screen still sticks out pretty far from bezel compared to original screen. Is this typical for the IFixIt screen? Do I need to apply more force to get screen to seat properly?
If I apply a lot of force to the bottom, near home button, the bottom of the screen shows a variety of colors, as though it’s knocking something internally
Note that Touch ID doesn’t work either—I get the error message as soon as the phone boots up.
I’ve redone the screen replacement process multiple times, to ensure problem was replicable. Thanks for help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I just switched out the cracked OEM screen, and touch ID/home button started working again, although now home button is hyper sensitive--I will have to return this screen and send the phone in to Apple, due to Covid19.
댓글 달기
답변 1개
가장 유용한 답변
Apple doesn’t supply screens to ifixit so expect aftermarket ones to be slightly thicker. And odds are apple will know you opened it up and refuse to repair it. Order a replacement from Mobile Defenders or Mobile Sentrix and you should be good to go.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Austin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 186
