주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
140 질문 전체 보기
Sometimes my MacBook Air trackpad freezes. (Trackpad Problem)
Device info : MacBook Air 11-inch Early 2015
Battery Cycle : 170
Hello! I have a question about a problem with my MacBook Air.
When I'm using my MacBook, sometimes the trackpad freezes and then works again, or after the trackpad stops completely, and i get a notification that "No trackpad found" and "Wait for a Bluetooth trackpad to be discovered"
I tried SMC reset, PRAM/NVRAM reset, and reinstalling macOS because I suspected a software problem, but it didn't help me solve it at all.
And this is really an occasional problem, sometimes the screen turns off suddenly while using the MacBook, and when i press the keyboard or touch the trackpad, the screen turns back on and the login window pops up.
The trackpad problem is the most serious and interferes with the use, so i'm writing here to hear from experts.
Thank you for reading! I will be waiting for your good opinion and solution.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If you are only loosing the trackpad and not the keyboard, that points to the trackpad its self MacBook Air 11" (Mid 2013-Early 2015) Trackpad and this guide MacBook Air 11" Early 2015 Trackpad Replacement
MacBook Air 11" (Mid 2013-Early 2015) Trackpad 이미지
상품
$109.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Junhyung Sung 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 7
전체 시간: 357
