주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
20 질문 전체 보기
Where are the power on pads?
I’m looking for the power on pads on my Macbook Pro 13 Retina Late 2012. Can’t seem to find a guide to look for them on this particular model.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This series does not offer power pads, the best way to check the system without the keyboard (or one you suspect is bad) is to disconnect all the cables as well as the battery, Now press the power button to finish discharging the circuit for a good 15 sec’s. If the keyboard power button worked reconnecting the battery should spontaneously boot the system. If not either the systems logic was not discharged as the power switch connection was bad or the logic board its self has a problem.
While it’s possible to probe the keyboard connector contacts to short out the power switch lines I don’t recommend that, as you can damage the contacts. Instead I use a spare keyboard which I can plug-in to test things.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for the quick reply! Well, unfortunately I’ve already probed the keyboard connector contacts and now the fans are going in max power (it’s been an hour already like this) and the screen is blank.
When do you think the fans will stop?
Thank you.
Thats not good ;-{
Lets back up here what was the start of the story... Clearly this is the end of it. Maybe we can change it ;-}
댓글 달기
답변을 추가하세요
Gabriele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 80
