주요 콘텐츠로 건너뛰기
납땜은 두 금속 조각 사이에 다른 필러 금속을 녹여 두 금속을 연결하는 방법입니다. 납땜에는 여러 가지 종류가 있지만 이 글에서는 전기 납땜의 기본을 알려드리고자 합니다.
Connecting an ESD mat to GFCI ground
The attached photo shows my situation. I’m trying to attach an ESD mat to ground, and the nearest outlet in my basement man-cave is a GFCI outlet. Is there an obvious way for me to attach the grounding cord? You can see it in the foreground of the picture. It’s intended to attach to the central screw of a normal outlet.
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
hi, There's no image showing with your question.
Here's how to do this in ifixit 기존 질문에 이미지 추가하기
Done. Thanks.
댓글 달기
답변 1개
선택된 해법
Hi
It appears as though the power supply wiring is in a metal conduit, is this correct?
Is it earthed?
If it is then just hook up the ESD mat to the screw on the conduit or the socket mounting box.
I'm suspecting that it should be earthed but that may depend on the electrical wiring standards where you are. It is where I am, to prevent the pipe from becoming “live” due to a possible wiring fault
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Some professional electricians added the outlet boxes a number of years ago, and I have reason to believe that they followed standards. So I’ve done as you suggest, connecting the cable to one of the screws in the corner of one of the boxes. Thanks!
댓글 달기
답변을 추가하세요
David Weld 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 374
