주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
20 질문 전체 보기
Why is my screen flickering
Why is my screen flickering but when I use a HDMI cable and plugging in to my tv monitor it shows good on the tv monitor what could be my problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The video signal pathway is quite complex! From what you are describing your logic board has a problem with one of the MUX units. So the load of the HDMI connection is enough to calm the noise.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I have no noise my problem is my screen flickering when I use HDMI cable and hook it up to my tv monitor it works perfectly on the tv monitor and everything else work perfectly it's just my screen
The word 'noise' is not what you hear its the interference on the electrical lines within your system.
Think of it this way you have a loose fan blade in your desk fan that is banging away.
If you touch the blade cover guard your hand is able to cushion the banging so now it's not making any noise.
So using that example your internal screen is like the loose fan blade banging on the cover guard. Now you plug in the HDMI cable which is like your hand silencing the noise of your desk fan.
Does that help explain whats happening?
You'll need to get your system to someone with the needed skills and access to the needed parts to fix your logic board.
댓글 달기
답변을 추가하세요
HAKAN OZBILGEN 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 66
