주요 콘텐츠로 건너뛰기
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
Webcam repair or replace on xps 15 9570
I wonder if i could replace the webcam on xps 15 9570. I see purple lines on the monitor. Drivers are ok. I dont know if i could repair it ir replace It and how.
THX very much
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개:
I've also got the same issue and dell hasn't addressed anything about it even after I've complained several times.
댓글 달기
답변 2개
Hi,
You may be out of luck in just trying to replace the webcam module.
According to the service manual (taken from this webpage), in the display assembly removal procedure section, once the display assembly has been removed from the palmrest assembly, it states on p.62:
The display assembly cannot be further disassembled. If the display bezel, display panel, camera module, display cable and touch-screen cable (optional) are defective and need to be replaced, replace the entire display assembly.
I have found a web cam module replacement part (supplier example only to give idea of what it looks like and the cost) but cannot find out how to safely dis-assemble the display so that the webcam can be replaced. You may have better luck.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
great answer! and so fast! THX
댓글 달기
I don’t know this particular laptop but Dell laptops of this era are generally petty repairable. You just have to remove the screen bezel (the iFixit jimmy is good for this), possibly after removing 2 or 4 screws, likely hidden under rubber screw caps. The webcam will then be visible, and retained by 1 or 2 more screws. Unplug the old one and plug in the new, reassemble and you’re done!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
david_rpz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 2,657
