주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
MacBook Pro Late 2013 unable to write to ANY external media
Weird one.
My MacBook Pro, Late 2013, is unable to write to ANY external media. Anything that is plugged in (by which I mean SD cards or USB drives) comes up on the desktop, I can read file contents, but cannot write. No matter which port I plug it into.
I have tried the media on other (various) devices (iMac, MacBook Air & another Pro) and it works everywhere.
I have created a new user, and tried there- no luck.
I have tried to alter permissions on the drives, but they say I should be able to read AND write.
Help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If the read works, there is nothing wrong with hardware.
When in doubt, reinstall OS.
Or it could be just you were trying to write to a NTFS volume on a Mac, which is not supported natively.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Go into Disk Utility > Disk First Aid select your external USB drive did it find a problem?
After you’ve copied off the data on the USB drive go into Disk Utility again and this time reformat the drive to GUID Journaled file system afterwards see if you can then write to the drive.
Also what macOS are you running? And if you’ve got any antivirus apps running and if they are all upto date?
Update (04/29/2020)
Sadly, this is starting to sound like a PCH level problem. A rare one for sure!
Apple no longer offers a block diagram in many of its schematics so this is just for reference. In this series the PCH is part of the CPU package
As we can see all of the USB connections go the PCH logic! Time for a new logic board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It began when a new SD card I bought couldn’t be written on, and yes- that was when I tried first aid and formatting it in Disk Utility. Neither worked, it errors out.
The same drives are in perfect health according to other machines.
No antivirus, OS X High Sierra.
댓글 달기
귀하의 답변을 추가하세요
pabz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 38
