주요 콘텐츠로 건너뛰기
Following the form of Lenovo's slimmer, smaller Yoga two-in-ones, the Lenovo IdeaPad Flex 5-1570 gives you great performance, using an Intel Core i5-8250U 1.6GHz processor and an integrated Intel UHD Graphics 620 video adapter.
10 질문 전체 보기
Why does my keyboard only work when I press down hard on palm rest?
Like the title says, my keyboard only functions properly when the palm rest is pressed down in a certain way. Most of the time, the home row keys will not function and the other keys will work perfectly fine.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Sounds like a loose connection.
Turn off and turn laptop bottom up.
Go to and read repair guide:
Lenovo IdeaPad Flex 5-1570 Motherboard Replacement
Look at the Step 3 photo where you will see 4 ribbon cables connected just above the battery to the right end.
The 4 cables are:
  1. Finger scanner cable.
  2. Touchpad cable.
  3. Keyboard backlight cable.
  4. *Keyboard cable (the largest ribbon cable on the right).
All connectors for flat cables unlocked the same way.
Lift up the 4th connector locking tab and pull the cable out and then reinsert it pushing down the connector locking tab.
Put the cover on without screwing back on, turn the laptop right side up and turn on and test the keyboard.
Does it work?
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
This fixed it!!! You just saved me so much money on getting a new laptop or getting this one fixed! Thank you so much for all of your help!
댓글 달기
귀하의 답변을 추가하세요
Gabe Brenner 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 12
전체 시간: 1,424
