주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Screen very dim after replacement
Guys maybe you can help me, after the screen replacement the brightness of the screen is very very low, almost impossible to see I have to put a light against the screen to see something, what can it be?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi Francesco,
It sounds like the backlight on the screen is not working. This may be due to a blown backlight circuit—which may happen if you tried to reconnect the display with the battery attached and powering the logic board.
You can try to carefully re-seat the display connectors (make sure to disconnect the battery first) to see if that will solve the issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks, I think you are right, I probably didn't realised when I was connecting the display the battery was still connected. Unfortunately I tryied to re-seat the connectors but nothing changed. Sometimes seems the backlight is coming back, like flashing for one second.
댓글 달기
귀하의 답변을 추가하세요
Francesco Bandinu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 245
