주요 콘텐츠로 건너뛰기
모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
212 질문 전체 보기
Blank screen after HDD replacement
Hi,
I replaced my Late 2012 21.5” iMac’s HDD with a Samsung 860 QVO SSD.
Even after I had watched guides on YouTube I managed to fail. :-(
Unfortunately, I made some mistake and now my system is not starting. I hear the chime, but after that the screen is blank. I get not signal with external display either.
Is there a way to troubleshoot if the logic board is broken? Or is it only the screen?
Thankful for help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hi , from the info supplied !
if the computer was 100% working before changing the hard disk , then check the display cabe behind the screen if it is plugged proper or damaged , as it is bit short and u need to take care on opening and closing
if that all ok , then see the graphic card
please let me know why did u change the hard disk !
all the best
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi
I wanted to upgrade from HDD to SSD.
I'm quite sure the cable or the connector on the screen is OK. It look a bit damaged. Why is LED 1 OFF after turned on?
댓글 달기
On the logic board are four onboard diagnostic LED’s which can give you some clues
Here's a breakdown of the onboard diagnostic LED's:
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
BEFORE TURNED ON
LED 1 OFF
LED 2 OFF
LED 3 OFF
LED 4 GREEN
AFTER TURNED ON
LED 1 OFF
LED 2 GREEN
LED 3 GREEN
LED 4 GREEN
I think you got the numbers wrong, You need to read from the bottom going up.
4 =1
3=2
2-3
1=4
Right. OK. Then, LED 4 is OFF. That would indicate that my Display is broken?
That is likely the display cable or the logic board connector. Basically the signals are not getting through.
Hi. One end of the screen cable is broken. Thus, I start with bying a new cable.
댓글 달기
귀하의 답변을 추가하세요
Anseli 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 112
