주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1059 또는 A1099 / 20, 40 또는 60 GB 하드 드라이브 / 터치 인식 클릭 휠
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 7개
가장 유용한 답변
Sounds like replacing the battery would solve the problem.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
please start a new post- just ask a question :)
의 공유
댓글 달기
Have you tried a soft reset first to get back to the startup screen?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
이 답변이 도움이 되었나요?
점수 0
댓글 달기
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
tell me what i cant do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
cindy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 3,667
