주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
Third party charger burned the charger port
So my computer works fine and still charges fine. I bought a fake MagSafe 2 charger off amazon and thought it was okay. It stoped charging, and I took a look and found that one of the “female” receptors- or beads or whatever of the five metal inputs is- Is burnt looking. From research online it looks like the charging port is separate from the rest of my computer so it should be fine if I get it fixed? It works fine now and charges with a VERIFIED apple charger, should I be worried about frying my computer if I continue to charge it for the time being?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
First here’s the needed part MacBook Pro 13" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board and here’s the guide to put it in MacBook Pro 13" Retina Display Late 2012 MagSafe DC-In Board Replacement
As far as using your system in this state the connector is setup to supply power of two pins for each side
So while its mate pin can power your system the resistance can create heat which could effect your systems running if you are running anything heavy. Best to cool it with the video or music composing or game play which tend to run the CPU hard.
This part connects the AC wall adapter power to the logic board. 이미지
제품
$29.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Sometimes this problem can occur when charging without a dedicated charger.
So I recommend you to use its own charger instead of this...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@george441 - Not sure I follow you here. Apple's chargers have been copied so you can have two on your desk, one real the other fake!
You can't tell which is which! Don't Replace Your MacBook Charger With a Cheap Knockoff and this is the most visible clue! Lacking safety features, cheap MacBook chargers create big sparks
This arcing tends to foul the connector contacts with a buildup of burnt crud which is what has happened here with Hess's Mac.
There is even more risks! Many also damage the charging logic within your system as well. It doesn't pay getting these cheaper chargers.
댓글 달기
답변을 추가하세요
Hess Mcdonough 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 157
