주요 콘텐츠로 건너뛰기
My Dell G3 is stuck and can't even be shutdown. What do I do?
I bought this laptop around maybe 7 months ago from UAE. I was playing some apex legends and then the screen froze so I thought maybe windows crashed. But then I couldn't shut it down forcefully using the power button and it's stuck in this screen. I have no idea what just happened. Could someone give some advice on what to do.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Hi,
Have you tried pressing Ctrl + Alt + Del (all three together) and check if you can shut down this way?
Old fashioned but still works.
댓글 달기
답변 2개
선택된 답변
You could unplug the the input power then remove the battery wait awhile then replace both sources of supply.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Service Manual:
https://www.dell.com/support/manuals/nz/...
Take of base cover and disconnect the battery.
Press power button for about 15 seconds and then reconnect the battery.
Look in manual for the memory modules. Release and then reseat the modules.
Replace base cover.
Does it boot up? Is everything O.K. now?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Nihal Noushad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 1,233
