주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
9052 질문 전체 보기
Dévant Tv started blinking with two vertical bars
So yesterday, the tv just went black and theres two vertical bars and they were blinking as soon as I arrived from downstairs. I dont know what happened, I tried pressing buttons from the remote, wont work, the little analog stick from the bottom of the tv, didnt respond either. Next morning, still blinking, the tv model is 50UHV400.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Red-Like Pines  this is a bit of and Off-brand make and model and maybe difficult to find proper information on it. For now I suggest that you unplug everything from the TV. Unplug the power cable. Then hold the power button down for something like 1 minute or so. After that only plug the TV in and turn it on. See what it shows you. If that did not change anything, you will need to remove the back cover. Check the power board, main board etc. for any burned charred or missing components. Post some good images of all of your boards with your question so that we can see what you see and possibly help you fix this TV. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for your reply! I unplugged everything from the tv and hold the power button for about 1 min like you said, and the tv didn’t really change much. I can’t open the tv for now, as it will void the warranty and I’m still waiting for the contact support to reply to me, please understand. If they can’t guarantee the warranty, then its all game. Once again, thank you for the help, I’ll contact you again if there’s any update to the case.
We got in contact with Devant a month ago, they said it was a factory defect and would try to fix the issue. Thank God we didnt lose the warranty or we’re gonna have to pay for it.
I got into contact with the place we bought it from, i didnt want to risk breaking it more, the tv was expensive as it is.
댓글 달기
귀하의 답변을 추가하세요
Red-Like Pines 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 60
