I have asus tuf a15, I have the exact problem, every driver is updated, windows and bios are updated. Some people say that this is a windows bug. I dont know if other laptop from other brand have this issue too.
Realtek 8822CE Wireless LAN 802.11ac PCI-E NIC
That is my wifi adapter.
Let me describe my problem more. This happens randomly, while gaming, or just using discord and zoom, and even after I just restarted. The wifi suddenly disconnected and when I check the wifi, there is no available wifi at all. To make it work again, I must use windows troubleshooter and it resets my wifi adapter. The problem being describe as wifi adapter or access point. And after than the wifi MAY continue to work, or it failed to start again and if it success, it may be fcked up again after a few minutes or even seconds. If it failed, I need to restart my laptop. But sometimes I need to restart like 3-5 times to make it work again. The wifi and mobile hotspot button at the internet icon in my taskbar are gone if it failed to start. And in device manager, it says that the device is not connected.
I HAVE BROUGHT MY LAPTOP TO ASUS SERVICE CENTER ONCE. They don’t know what’s wrong (that maybe means the hardware is not the issue)
EDIT: It has been months since I encountered the problem and somehow it fixed itself. I don't make any change, or I don't know that I did. There's a good chance it's hardware problem.
EDIT 2: Try reinstalling the WIFI card, by which I mean physically unplug and replug it again in the socket under the SSD. My friend said it worked for him. You can also try to clean it.
댓글 7개
What brand is the wireless network card?
Pedro 의 공유
getting this problem when play games on steam and epic
David Thomas 의 공유
exactly the same, while play games or smth
Bayu Rezha 의 공유
I have this problem too - persists after doing all the drivers troubleshooting and even replacing intel 9462 card. Now on fresh windows install wifi adaptor is not found. I think motherboard is damaged from heat. Trying next with wifi dongle. Not a software issue or directly related to wifi card.
jo jo 의 공유
Interesting way, that Asus AVOIDS RESPONSIBILITY.
User has to “exchange the wifi-card” - and then “voids warranty”.
Asus has now done this, with a lot of laptop-models.
Any user, has the option:
- either spend extra money on getting an Authorized Asus-person/approved repairman doing the simple exchange.
(and “not having the laptop” for maybe 2-3 weeks! if it needs to be sent in!).
- or, go and buy a cheap Intel wifi-M.2-card … and Void warranty.
I would like to BAN ASUS, for this way of cheating the customers of their rights!! …
Notes:
- the wifi-cards are in some models (FX505, etc) placed just underneath the SSD (making the wifi-card easy and tempting just to change).
- the RAM & SSD/HDD are just as simple to change …. without loosing warranty.
- any user, getting into the inside, to change/add ram/ssd/hdd, will see the wifi-card.
- this “suspiciously, all too bad” wifi-card, well !! …
- The same “fault/mistake” (choosing a suspiciously low-quality / crappy wifi-card) IS Asus-STANDARD!!
- It SMELLS VERY BADLY …. and Asus should be ashamed of themselves!!
Peter Siltic 의 공유
댓글 2개 더보기
