주요 콘텐츠로 건너뛰기
모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
212 질문 전체 보기
White Screen After upgrade
I recently upgraded my, hard drive to an SSD, RAM to 16GB, and CPU to an i7. The upgrade went well.
The iMac booted up and I installed Mountain Lion. Then upgraded to Catalina. The computer worked great for a week really fast.
Then it got stuck trying to close a program. I waited for about 15 minutes and then when nothing responded I did a hard restart. Now I get only a white screen on boot with the chime. Here is what I have tried:
  • Restart with D pressed- nothing
  • Restart into safe mode (shift) - nothing
  • Reseting the PRAM - Chime and white screen for a second then reboot. Still at white screen.
I have removed the display again to look a the diagnostic LEDs. They look normal. Single when plugged in. Second on boot, third quickly follows and no fourth. I replaced the display and all four LEDs light.
What additional steps can I try?
It seems really odd that it was working for a week with no issues but now won’t boot.
RAM and SSD are from OWC and the CPU was purchased used.
I swapped the other CPU back in but still nothing.
Thanks for any help or suggestions you can provide.
Here are the images of the display connectors.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If the onboard diagnostic LED’s are lit that tells me your display its self has a problem. I would see if an external monitor works, if it does then that proves it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
That is a good idea Dan. Thanks. I will have to get a mini-display port to HDMI before I can test. Do you know if the iMac will immediately recognize the external monitor? I can't get into the settings to change anything.
You should see your desktop.
Hi Dan, I got the cable and tested it. I still only see a white screen (with the boot chime) on the imac. The external display show no signal. Do you have any suggestions for how to troubleshoot? Thanks
OK now we have a conflict of diagnostic processes. You stated the onboard LED's #1, #2, & #3 lit and as the display was not connected #4 was not lit.
Now you're telling me the external display is not working. So thats telling me your GPU has failed or your logic board display data cable connector logic has been damaged.
Open the system up carefully disconnect the display again and take some nice clear pics of the connector (tight) and of the logic board around it (a good 3 inches) post them here for me to see 기존 질문에 이미지 추가하기
Hi Dan, Really appreciate you help with this. I did not understand your original suggestion. I tried the external monitor with the iMac display attached. I just tried plugging in the external monitor without the display. Still just the white screen. The three LEDs light but not the fourth. Would that point to the logic board?
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
Morgan Grundy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 116
