주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
QWERTYUIO not working-I know there are some post re this BUT none work
I just switched out my dead logic board on my Macbook Pro 13” mid 2012.
Everything seems to be working but some keys in the keyboard are not. Specifically, QWERTYUIO [ ] = and the power button. Oddly enough P works fine.
I have tried everything I found here. I can’t reset PRAM or SMC because both require buttons on the keypad that aren’t working. Are there other solutions that aren’t already listed here on ifixit?
By the way, the keyboard was working fine before the logic board died. I don’t think it’s the logic board based on everything I’ve read here. I know there is a solution but, for the life of me, I can’t find one. Please help.
Thanks,
John
Two more photos:
Edited: Here is a photo of the ribbon. I’m pretty sure it’s connected correctly.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Is an external USB keyboard works ? Check if the keyboard ribbon cable is well inserted into the connector, also look carefully at the connector and the cable end. Also verify the keyboard connector area for missing or damaged capacitors or resistors or corrosion in the area. Good luck :-)
해당 답변은 도움이 되었습니까?
점수 3
댓글 6개:
I'm going to try an external keyboard. I did check the ribbon. I don't see any damage but it possibly could be damaged with all the attempts I made to plug it in correctly. I finally used the tape method to insert it properly. I don't see any corrosion or damage. I did clean the area with compressed air and also isopropyl. No dice on either one of those. This seems to be a common problem with MBPs and makes me wonder if I'm missing some easy fix or not doing it right.
@donjuanelguapo - The issue is getting the connection secured properly to the logic board. I've seen cables not inserted fully, damaged cables as well as damaged logic board connector. Yes, getting the cable in is a bit tricky!
Post some pics so we can see things: 기존 질문에 이미지 추가하기
@danj Photo added to original post.
@donjuanelguapo - Can you take a second one with the latch up so I can see the solder joints under it.
@danj Photos added to original post. Sorry by phone doesn't take clearer pics.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
John 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 131
