주요 콘텐츠로 건너뛰기
27" 화면 2560 x 1440 픽셀 해상도 Thunderbolt 및 MagSafe 케이블 부착물
160 질문 전체 보기
Green display on turn off, clearing after 10-15mins
I have had my thunderbolt display for a while and no issues until one day it seems to click, and the green appeared.
After about 10-15mins it disappears and the screen is back to normal.
The green is all over with what looks like some image persistence at the sides.
I have stripped the display back but could see anything obvious then wasn’t sure what to look for. I gave everything a clean with a blower, a long shot but no joy…
Any advice welcome.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Try cleaning the connections with a qtip and alcohol and a soft brush, there might be corrosion just from the humidity in the air.
Update (05/21/2020)
If you open it up it should have a connection where you can change the screen.it should be internal. I use Rubbing alcohol as high of a percent of alcohol.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi Allan, thanks for coming back. Which connections? And what alcohol is best?
Done and unfortunately no change...
댓글 달기
귀하의 답변을 추가하세요
James 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 35
