주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
I can change the cpu?
I can change the serial i5?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sorry the chip its self is not socketed as such you can’t replace it.
But! What you can do is swap out the logic board with a better CPU. This series also has a known issue with the dedicated GPU I would recommend you look at installing a 2012 logic board to get both a better CPU but also a better GPU!
The board is a direct drop in with just one minor alteration needed in the LVDS cable as the newer board has a slightly different connector. All you need to do is use a nail file to file down the cable connectors tang ever so slightly on both sides.
Here’s the logic board info for the 2012 boards
  • 661-6491 - 15” Macbook Pro 2.3GHz i7
  • 661-6492 - 15” Macbook Pro 2.6GHz i7
  • 661-6493 - 15” Macbook Pro 2.7GHz i7
Here’s one source for the part 15” Macbook Pro 2.6GHz i7 Logic board
And here’s the guide to put it in MacBook Pro 15" Unibody Early 2011 Logic Board Replacement
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Pipe Lol 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 144
