주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
No wifi/Bluetooth, no power to rightside USB after battery replacement
Hello everyone,
I have recently replaced the battery using the ifixit toolkit on my late 2012 rMBP 13” running MacOS Catalina. While that seems to have been successful and the MacBook powers on without issues, wifi and bluetooth no longer seem to be working. Furthermore, I don't seem to have power to the right side USB port (could be the whole side).
I have performed an SMC reset and reset PRAM without any success, which makes me believe it is a hardware issue. I/O board data cable perhaps? Opened up again and checked over everything, but nothing seems to be out of order or visibly damaged.
Update (06/03/2020)
Problem solved. Will mention in case someone has this issue in the future.
The I/O board data cable connectors had been deformed somehow during my disassembly. Notably, the data cable fit just fine even though the connectors were deformed. I used one of the fix kit tools to bend the connectors back to their original shape/position and everything is now back to normal. It's definitely a part that needs to be paid attention during assembly/disassembly.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Check the I/O board and its cable MacBook Pro 13" Retina Display Late 2012 I/O Board Replacement
The Airport is mounted to it and this can also explain why your USB port is also failing.
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board 이미지
상품
$49.99
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable 이미지
상품
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
bgdimitrov 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 236
