Ethernet doesnt have a valid IP configuration
I just bought a new motherboard because i was having some major issues with my last one. It unfortunately didn’t come with the driver disk. But i was able to get it all online and its updated. But now im having this issue where i get the error “Ethernet doesnt have a valid IP configuration” At first it woulnt’t even show it was plugged in till i changed “auto disable gigabit” to “relink, battery or ac” and disabled both “Energy efficient Ethernet” and “green Ethernet” Iv tried the following to fix the problem:
Disabled/enabled
Unchecked “turn on fast start up”
Entered in IP and DNS myself
Uninstalled and reinstalled driver
Restarted the router
disabled IPv6
unplugged pc and hit power button for 30 seconds
reset windows 10 with keep files (these worked for about ad hour after then went right back)
Command prompts
- netsh winsock reset
- netsh int ip reset
- ipconfig /release
- ipconfig /flushdns
- ipconfig /renew
I tried to stop/restart DHCP client but i get an error (Error 5: Access is denied) and i run is as admin
There are times some of these will work but then it will go right back to no ip config. Iv tried searching the internet for other solutions but these are all the solutions i get but none have worked.
The network driver is Realtek PCIe GbE Family Controller
좋은 질문입니까?
Hi @darkstorm824
Had you tried with another LAN cable?
There is another way to test, by using Live Linux, see if it works to.
Just to check if this is a fresh install OS?
Augustine 의
Hi @darkstorm824 ,
What is the make and model number of the motherboard?
What is the status of the LAN network adapter in Device Manager?
jayeff 의
@salmonjapan Yes iv tried a different LAN cable and different lots on the router. It wasnt a fresh OS install. I only updated my motherboard.
Jae 의
@jayeff its the asus h97-plus and the status says its working correctly
Jae 의
@darkstorm824
Does it work OK in safe mode with networking?
jayeff 의
댓글 5개 더보기
