My washer is plugged in a good working outlet but still no power ITS a
my whirlpool washer is plugged in a working outlet but still have no power to washer
좋은 질문 입니까?
좋은 질문 입니까?
How did you test to make sure the outlet worked? You need to use a volt meter and verify it has 110/120 volts at the the outlet. Then make sure you have voltage going into the washing machine. Open the back where the power cord comes in. Someone said that you had another ad that said it made a loud pop with smoke and the breaker tripped. If that's true then you have a short.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 344
Hi @donaldvs ,
What is the model number of the washer?
You commented in another answer that the washer blew a house fuse when it was plugged in and now the washer doesn't work is this correct?
If so do you have a DMM (digital multimeter) and know how to use it?
Also take some close up pictures of the washer's control circuit board and post back here as something may be seen. Here's how to do this 기존 질문에 이미지 추가하기
Be safety aware and ensure that the power is disconnected from the machine when you're working on it.
jayeff 의
