주요 콘텐츠로 건너뛰기
Model A1199 / 2, 4, or 8 GB capacity
85 질문 전체 보기
Not turning on after chargng, turns hot though.
Hi
I connected my Ipod 2nd Gen 8GB for charging and left it connected to the laptop for 3-4 hours. It was charging fine, but when i went to unplug it, it was hot on the back side and wouldn't turn on.
I tried resetting it but no go.
I connected via usb and tried a reset, no go.
I tried electric adapter (wall connector) then reset it but no go.
Now when i connect it to the electric adapter the back side does get hot (right behind the wheel).
Is the battery fried ?
How can i verify that ? (i can manage a little bit if electronic repair & i have a soldering iron too).
Thanks in advance for your response.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
It's quite possible that it could indeed be the battery. According to our teardown the battery is located directly behind the click wheel.
I had a similar incident happen to me with a rechargeable battery for my mouse. The lithium ion pack got really hot and swelled up a bit. Does your iPod look swollen on the back at all?
The good news is that it's relatively inexpensive to replace the battery for that model. It looks like we have some extra batteries in stock and we've got a guide for replacing the battery. It's not for the faint of heart (you need to do some soldering), but you sound like you can handle it.
Good luck!
iPod nano (2nd Gen) Battery 이미지
상품
$13.99
iPod Nano 2nd Generation Battery 이미지
안내서
iPod Nano 2nd Generation Battery Replacement
난이도:
매우 어려움
45 minutes - 2 hours
iPod Nano 2nd Generation 이미지
안내서
iPod Nano 2nd Generation Teardown
난이도:
아주 쉬움
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
ffilling 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 3,395
