CPU is running at slow speed, battery not charging after water spill
I spilled some water on my MacBook Pro Early 2011 keyboard. Water went all the way down to the logic board. I disassembled everything and dried it out. Then cleaned the logic board with some Isopropyl alcohol. I then reassembled it and found that it starts booting OSX but then get’s stuck at about 75%. Once I was able to get to the login screen, but then it froze. I was able to boot into Windows 10 and log in. I then checked CPU-Z and see that CPU is always running at its lowest speed (about 700MHz if I remember correctly, multiplier seems to be fixed to 8). Also the battery is not charging. It shows the battery is present and charged above 90%, but it’s not charging to 100%.
I tried resetting SMC but not sure that it worked. At least I have not seen the light on the magsafe connector changing colour.
So the thing seems to be working overall, but far from normal. Is there anything in particular I should check on the logic board to found the reason? Any voltages that I need to check and where?
Thanks a lot for advise
좋은 질문 입니까?
Install this gem of an app CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기 make sure the charger is plugged in when you test things.
Dan 의
Battery started charging now. CPU is still very slow and fan is running fast. What else can I check?
skvortsovsn 의
Can you post the snapshot so we can see whats happening.
Dan 의
Hello, how do I make a snapshot? Thanks
skvortsovsn 의
From within your Finders menu bar go to the Help menu and then look for Take screenshots or screen recordings on Mac It will offer a full explanation on how. Make sure you're not running an app otherwise you'll see the apps help topics.
Dan 의
