주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 질문 전체 보기
Is it possible to repair middle button operation?
The middle button of the click whee is not responding. Is it possible to repair it without replacing the entire front plate?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
You will have to disassemble it. Check the micro switch on the logic board right under the middle button. Make sure it has a click feel to it. If it seems to feel like the other ones, I would start by replacing the click wheel. Also make sure the middle button makes good contact with the switch. this guide shows you how to remove the logic board. the click wheel is right under it....Good Luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks very much. I'll give it a try.
you are welcome and let us know how it is going. If you need more help, just ask..;-)
댓글 달기
귀하의 답변을 추가하세요
rjantoniono 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 724
