Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
좋은 질문 입니까?
좋은 질문 입니까?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
안내서
난이도:
쉬움
5 - 10 minutes
안내서
난이도:
운영
1 hour
안내서
난이도:
운영
9 - 15 minutes
해당 답변은 도움이 되었습니까?
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
해당 답변은 도움이 되었습니까?
It's much cheaper just to replace the gasket or the valve of the tank.
24 시간 전: 1
7일 전: 8
30일 전: 37
전체 시간: 2,002
