주요 콘텐츠로 건너뛰기
500 GB touchscreen laptop with an Core i3-3217U processor and 11.6 inch screen.
3 질문 전체 보기
Asus vivobook s200e stuck in windows logo
So I have an Asus vivobook s200e laptop and I had a boot loop error, bypassed it and now the windows logo will stay on and the circle will keep on spinning for forever. When it was done it had an error that says your pc couldnt start properly which made me to believe that my laptops ssd might have gone faulty. Is there any fix to this or any other reason why this happens and do i need to buy a new ssd replacement? Thank you
Edit: Finally got pictures but theyre kinda… bad
error 0xc00000e9 comes first, then 0xc000000f when i do the startup option (F8)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Update: Ive done and replace the hard drive as i was getting so frustrated by this, cost me like $70 for a new drive but now it works back again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Hi,
Try the Chosen Solution from this link
Asus laptop loop restart
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Dude thanks for this, i managed to bypass the bios thing but now the problem is that it says the winload.exe is corrupted or missing. Does the solution still work in this situation or no?
@Red-Like Pines
If you repair from the USB it should as it loads and repairs from the USB files and not the laptop's recovery partition files.
If attempting to repair from the laptop's recovery partition (3 x shutdown method) caused the problem you now have then it may have been corrupted.
If this is what you get when booting from the OS as per normal then you can try repairing using the laptop's recovery partition (3 x shutdown method) and see if it fixes it and if not then try the USB recovery method
댓글 달기
귀하의 답변을 추가하세요
Red-Like Pines 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 295
