My 2ds doesn't charge
Hi guys, a friend of mine gave me his old 2ds that does not turn on, i thought it would be a problem with the power connector. But, using a multimeter i can see that the 4.6 volts reach the pins that go to the motherboard from the back of the connector. I charged the battery with an external adapter and the console works correctly, could someone help me to check any of the components that may be damaged? Or do you know where I can get a point-to-point guide to know where the motherboard should have voltage? Thanks!
좋은 질문입니까?
댓글 1개
Hello guys,
I have the same issue, charging light come on for a short time and gone.
My battery is good (tryed it on another 2ds and works fine)
Did you manage to fix the issue ?
Thanks
Fares mouhou 의
