주요 콘텐츠로 건너뛰기
냉장고, 냉동고 및 냉장-냉동고를 포함한 식품 냉각 장치 수리 및 분해 안내서.
1698 질문 전체 보기
Defrost heaters not working
My defrosting system Ices up and doesn't melt down.
What could be the problem but then I tested the heaters and thermostat they cdnt pass through continuity test but rather bring up a reading of 433 reading
What could that mean
Then I also need help finding the timer of a RT31FAREDSA model Samsung double door fridge dual Inverter
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 7개
Hi,
What is the full model number of the freezer?
Did you measure the heater element and the thermostat, individually and in isolation i.e. disconnected from the wire harness and the meter probes connected directly to the component's connection terminals?
Normally for a good heater element the resistance measurement is 20-50 Ohms. Don't know about the thermostat.
Depending on the specifications of your meter a resistance measurement of 433 Ohms may be above the limit where the continuity test works as continuity is usually just a quick test to prove that the wire/switch etc is OK and it is normally only a very low resistance <1 Ohm.
Also what component measured 433 Ohms? That's definitely too high for a heater element.
Thanks for getting back to me jayeff
I appreciate, actually what I was working on was a fridge.
So the thermostat and the heaters were connected together and had two brown wire connected on either end, so I disconnected them from where they receive power and I set my multimeter to a ×1(where a continuity beep is always heard) so I measured (as they were still together) and that reading of 433 is wat I saw
So I got confused and I dnt know what is which
But you have said that that reading is really to high so I guess it's a faulty heater but then what about the thermostat.
Plus I failed to locate the timer of the fridge
Hi,
Your comment was deleted by the iRobot because it contained long number strings which it think are spam phone numbers.
I saw your deleted comment but the model number you posted i.e. Samsung RT 31FAREDSA, gets no results when searching online for that number.
Please verify that the model number is correct?
Also do not put personal contact details online as this can expose you to spam or worse.
Just commenting back here will get attention especially if you add @jayeff in the comment ;-)
Moderator
Hi @atuhutrire alison
If you measured the heater by itself and got that reading it is too high.
If the thermostat is a thermistor type then its' resistance will vary with temperature.
It might be one step at a time.
See my comment above about the model number. Usually there aren't that many letters in a model number
Which Model? Tell me your Model Name And Version.
댓글 2개 더보기
댓글 달기
답변 1개
가장 유용한 답변
OK I finally located your model (sorry about doubting the number)
It appears that it is a model for Africa.
There don't seem to be any parts suppliers or any other information e.g. service manuals that I can find online so you may have to contact Samsung, in your location and ask about where to obtain parts and their availability.
As I said, one step at a time.
If the heater solves the problem all well and good. You can verify the heater before installation by testing it to see what its' resistance is. If it is what I said then you know at least that the original is faulty.
With most refrigerators, they go into auto defrost mode once every 8-11 hours. During this time the compressor and evap fan are turned off and the temp in the freezer is allowed to rise to 0 deg. C to melt any ice which drains away to the evap pan under the refrigerator cabinet . The melting process is sped up by turning on the defrost heater.
When the temp reaches 0 deg. C the defrost thermostat operates to end the cycle by signalling the control board to turn off the heater and to restart the compressor and evap fan.
This whole process takes about 20-25 minutes and is repeated every 8-11 hours.
The timer is part of the control board
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Thanks Alot @jayeff
I will surely try that
Testing the thermostat and heaters differently to know which is which
Thanks Alot
@jayeff
I still have one question though
Where can I find the timer of this very refrigerator because I tried behind the kick plate(was tightly enclosed) and behind the compressor compantement nothing was there
@atuhutrire alison
You have to find the main control board.
It won't be a separate adjustable timer as you know it.
It will be in the circuitry contained on the main control board. These days most probably controlled by embedded software in an IC.
As I suggested check if the compressor does turn off for the length of time and not just for a shorter time because the set temp has been reached.
It's a pity that there is no service manual available because I've found with a lot of Samsung refrigerators that you can force the fridge into the defrost mode to test that all the functions are working. Without it all you can do is observe and test what you can. In this case only the heater and perhaps any sensors located in the freezer compartment near the evaporator unit.
If the compressor is never stopped for at least 15-20 minutes (and unfortunately this may happen at any time, if you don't know when it occurred last e.g. middle of the night) then there is a problem with the control board.
댓글 달기
귀하의 답변을 추가하세요
atuhutrire alison 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 730
