주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20001 질문 전체 보기
Do I need a new I/O board or a new battery to fix my problem!
Hello!
It’s my first time posting here but I figured this was the right place to ask. The battery on my retina 2015 MacBook Pro went into the ‘replace now’ status as I’ve had it a little while. It was only working when the charger was plugged in and the light stayed on orange and didn’t charge, as soon as the charger was removed the laptop would shut down.
I bought a brand new battery to hopefully get past this issue but now I’ve installed the brand new battery it still has the same status ‘replace now’ and only works on the charger. I was at a bit of a loss here as I wasn’t sure what the problem was, I checked out the new batteries health on Coconut Battery Health and the results are attached and say that the battery is totally healthy it just has 0 cycles. I tried an SMC reset and also I can’t calibrate it because it only works on the charger so I can’t drain the battery.
I then came across an article that said this is potentially an issue with the I/O board and not the battery at all. I don’t exactly know what the I/O board is but I know it’s responsible for the battery status so potentially replacing the I/O board will fix my issue and allow me to work again and actually use the laptop without the charger connected. Any other suggestions are ofc welcome if u think the issue is not either the battery or the I/O board. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
This question was migrated from https://meta.ifixit.com/Answers.
댓글 달기
답변 1개
가장 유용한 답변
You need to recalibrate the battery and do an SMC reset in order to clear the error most of the time. Once the SMC reset is done, recal the battery.
While this guide is focused on Windows machines, the same principles mostly apply to a Mac. The difference is you won’t be able to fully drain your Mac like a PC. For this machine, use it until it goes to sleep and charge it back up to 100%.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for the advice but this won’t work. The issue is that my Mac shuts off as soon as the charger is removed. So recalibration isn’t an option because I won’t be able to drain the battery as l take the charger out and it dies
Doubt i/O board would help. There appears to be a problem with power from the battery going to the logic board.
It is most likely a battery management circuit problem on the logic board causing this.
I bought a cheap Chinese battery so I hope that was the issue here as I just bought a genuine one just now. Is that also a possible reason for the issue? Just a bad quality battery?
댓글 달기
귀하의 답변을 추가하세요
Harvey Olszowski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 53
